Author Topic: car back fireing on full boost  (Read 2168 times)
03sharpe07
« on: 19:55, Wed 09 September 2009 »
i drive my car normal and it runs mint when i put my foot down it back fires with a loud bang :?  can any body tell me why
« Reply #1 on: 20:03, Wed 09 September 2009 »
How much boost is it running & is the bost cut still plugged in, 2 black wires going to the short boost hose..
r5_clio
« Reply #2 on: 20:38, Wed 09 September 2009 »
does it feel like its holding back when it backfires? if so try replacing plugs and leads because it cured that problem on mine when i wound me boost up
03sharpe07
« Reply #3 on: 21:10, Wed 09 September 2009 »
Quote from: "5teve L"
dont no i am going to rig up a boost guuge at the weekend if you are on about the sensor built it to the hose then yes it is mate  :?
03sharpe07
« Reply #4 on: 21:12, Wed 09 September 2009 »
Quote from: "r5_clio"
i will give it a try mate it has been sitting for about 3 years :lol:  cheers mate
red shed
« Reply #5 on: 21:37, Wed 09 September 2009 »
i had the same check for a boost leak 1st my intercooler split and it stutted under boost and then backfired its worth a try
red shed
« Reply #6 on: 21:39, Wed 09 September 2009 »
p.s or the overboost relay by the heaterfan for dirty contacts
Big Steve Raider
    • http://s306.photobucket.com/albums/nn259/BigSteveT/Raider/
« Reply #7 on: 21:51, Wed 09 September 2009 »
Disconnect overboost switch & see if it still does it?
« Reply #8 on: 22:17, Wed 09 September 2009 »
Quote from: "Big Steve Raider"
What he says...
03sharpe07
« Reply #9 on: 21:32, Thu 10 September 2009 »
i willl give it ago lads appreciate the help put new pulgs and leads on it today still doing the same standard boost gauge gose off the clock ??
« Reply #10 on: 21:34, Thu 10 September 2009 »
Quote from: "03sharpe07"
Sensible option would be return the boost to standard until you have an idea of how much boost it's running and what work has been done to the carb.
Just incase something goes bang.
