Author Topic: Back in the fold!  (Read 3566 times)
« Reply #15 on: 22:46, Wed 05 August 2009 »
much better penfold. its nice to see this car finially coming together
penfold1981
« Reply #16 on: 17:13, Thu 06 August 2009 »
wish us luck; MOT in the morning (Friday 7th of August)  :shock:
dave r5
« Reply #17 on: 19:37, Thu 06 August 2009 »
good luck with the mot mate
as long as every thing is good underneath it shud fly through.
dnt let them fuk u on sumink silly
even though it is  a free re-test
renault shell, custom cage, no dash, volvo engine, nissan turbo, apexi boost controler, ksm re-wire, persision automotive down pipe, dta engine management to come.  175 BHP 220 LB/FT torque
penfold1981
« Reply #18 on: 23:57, Fri 07 August 2009 »
MOT guy was a mate :-)
Passed with flying colours , a few stupid advisories but nothing major to worry about.
Apparently, if you loose your mixture screw from your carb you could just put a bit of blutack over the hole and your car will run okay until you get a new one :-)
Also, don't put the pipes on the actuator the wrong way round or it will just boost to infinity or until the over boost protector kicks in!!!
penfold1981
« Reply #19 on: 22:27, Sat 05 September 2009 »
today I have mostly been making a bracket for my collins -31 actuator!
gor the actuator for 26 quid from fleabay :-) Bargain. Actuator is the long rod type from a cosworth so I knocked up a bracket from 3mm mild steel but it flexed quite a bit when I fitted it so I put some extra bracing on it and that seems to do the job. Boost seems to be a little crisper now or maybe it's all in my head but it does look nice in the engine bay :-)
« Reply #20 on: 07:22, Sun 06 September 2009 »
Nice one, glad to see it's all coming along, good job on the bracket, seems everyone has welders these days :lol:
