Author Topic: Restoration  (Read 6539 times)
Re: Restoration
« Reply #30 on: 13:24, Fri 27 November 2009 »
Quote from: "JRP - SAT DIVISION"
Running... all sweet as a nut, need finnishing all little bits off etc :) spent tonight with a nice grey 5 is the shack of love :)
Hope you got home james :)
Your 5 sounded and looked fantastic, I apologies for the spunk marks up the rear window I couldn't control myself.
Yeah got home ok still not found the fecking oil leak obviously wasn't the fecking sump after changing it all at your place so that was 4L of oil lost on the way to yours and the same on the way home :(  bought more oil today, I have removed the OE Oil feed sensors and pipework and replaced with some good spares I have got so hopefully when I put the oil in this will be it as I can't see where else it is coming from.
Go any pics of the cars??
JRP - SAT DIVISION
Re: Restoration
« Reply #31 on: 09:38, Thu 03 December 2009 »
turbo oil reurn :) your leak... see sorted
Re: Restoration
« Reply #32 on: 09:52, Thu 03 December 2009 »
Yeah leak sorted must have been the original oil feed pipe from the block as I replaced with another cleaned block up and not lost any oil since been using the car the last couple of days just to go to and from work done just over 100miles now.  Just need to sort a bad hesitation problem when on boost now then she is done until the next problem thinking this is a fuel prob at mo.
DRAZEN NST
    • http://www.zafc.bigforumpro.com
Re: Restoration
« Reply #33 on: 13:09, Sun 31 January 2010 »
Nice project ;)
As the project progresses?
[size=200]NORTH SIDE TEAM Subotica [/size]
hondaman
Re: Restoration
« Reply #34 on: 23:01, Thu 04 February 2010 »
propper mint mate love it
Re: Restoration
« Reply #35 on: 13:44, Fri 05 February 2010 »
I was up JRP's place wednesday eve and to be honest it has progressed alot further now and now only needs a few things doing to be complete.
Brakes need bleeding,
Needs tyres + refurbed alloys,
Sideskirts need to go on (need long rivets),
Quick change of all engine fluids and new sparkies so general service bits,
Bonnet to go on,
Other than that she is pretty much there I will get John to add some more pics up
