Author Topic: my efi conversion  (Read 11237 times)
NaylsGTT
« Reply #15 on: 22:02, Mon 15 June 2009 »
Very nice! :)
what are your plans with this? drag car? what boost you gonna run?
an efi c1j has yet to be proven better than the carb (although it should be),nobody has yet proper gone to town with some boost down the pod have they?
zmangtt
« Reply #16 on: 22:04, Mon 15 June 2009 »
nice whats total price then? did u do all the work yourself or did u pay sum1 if so how much???
group a rally spec 5, group a head set an bolts not sure what the carbs had done, stage 2 turbo, bailey piston dump valve, uprated turbo elbow,full exhaust system, induction kit,cup mod,greddy boost controller,turbo timer,uprated carb elbow,uprated intercooler
RICHIE
    • http://www.renault5gtturbo.com/forum/viewtopic.php?t=5531
« Reply #17 on: 22:12, Mon 15 June 2009 »
nayls its richie from rtoc by the way.  my mate made the manifold up for me. as for efi on a c1j not that many people have really done it i can name only a handfull and yes there results were good im going into hill climbing as thats were the efi will be a gain as for boost i woul have at a guess 18-20 psi obviosly i can up that or drop it depending on how it all goes. i do all the work myself except for the mapping im yet to get my head round it but im learning.
zmangtt
« Reply #18 on: 09:18, Tue 16 June 2009 »
how much would u charge 2 convert mine matey?
NaylsGTT
« Reply #19 on: 10:32, Tue 16 June 2009 »
yep i knew it was you mate,the name give it away lol :)
i badly wanna see someone go mad on an efi c1j for santa pod,seems all the big boosters are still on carbs,which is strange as e.f.i should prove better & easier.
RICHIE
« Reply #20 on: 16:00, Tue 16 June 2009 »
Quote from: "zmangtt"
how much would you charge 2 convert mine matey?
at all depends on were you want to start what you budget is ect and your knowledge. the ecu alone is 550 100 wiring loom injectors are say 50 quid second hand. map sensor coil pack trigger wheel trigger sensor water temp sensor around the 100 quid mark for the lot. its just the manifold design you will need to work out what you want to do. i would budget for 500 pound for a manifold with throttle body and fuel rail. as for me doing it i wouldnt charge you as i do it as a hobbie mate but funds at the end of the day are your biggest issue.  the mapping i get done for fairly cheap by a autourised installer af adaptronic equiptment
RICHIE
« Reply #21 on: 19:27, Thu 18 June 2009 »
well had half an hour spare time today so dropped the engine in still a fair bit to do but only lots of little jobs. biggest job is finding a suitable fuel pump probaby end up going down the coosie route.
« Reply #22 on: 15:28, Fri 19 June 2009 »
Schaa-weeet!
When did you get it back in man? I need to give you this turbo back soon by the look of things.
RICHIE
« Reply #23 on: 14:39, Sat 20 June 2009 »
removed the old fuel tank last week and put in a smaller alloy one just looking for a fuel pump now that i can mount using the oe bracket if not i guess i will have to fabricate one.
RICHIE
« Reply #24 on: 19:56, Wed 24 June 2009 »
managed to plumb up a few pipes and work out were im moving things to ect just a sample of whats going on
RICHIE
« Reply #25 on: 19:09, Mon 06 July 2009 »
managed to move the header tank now so all good there and managed to fit my new injectors also made a ll in one scuttle cover not really visible in the pics.
RICHIE
« Reply #26 on: 20:09, Wed 08 July 2009 »
a better picture of progress now you can see the scuttle cover template in situ so im going to knock a carbon fibre one up maybe even stick to the white. i changed the header tanks plans slightly got rid of the heater matrix hoses all together along with the swirl pot so minimal hoses in there now. just means i have no heating but thats ok on track.  also decided today i didnt like the oe horn setup so removed the bracket for that and replaced the huge one with a little tiny electric one which can be heard rather than that little pwarp noise.
RICHIE
« Reply #27 on: 18:43, Fri 17 July 2009 »
finished of part of the boost piping cylinder head end plate is to have two sensor holes tapped into it. also got the strut brace to figure out i just need the bar making accross as it interferes with the pipe work. then need to get my ecu ordered up but was doing all the time consuming jobs first so not much to show really
RICHIE
« Reply #28 on: 20:07, Sun 16 August 2009 »
hardly any progress due to working away even though its for sale im still fitting all the bits i have bought for it exhaust elbow is fitted along with the bms downpipe. catch tank now fitted slightly lower due to the strut brace handles interfeering. cylinder head end plate now has the sensors fitted and the car is all filled up with its fluids.
« Reply #29 on: 23:36, Sun 16 August 2009 »
looks awesome. where will the other boost pipe run? also what management you hoping for it?
