Author Topic: few teething probs. hesitaion, no rear brake lights  (Read 4728 times)
r5gttraider
« on: 00:26, Sat 04 April 2009 »
when i got the car it had a set and forget boost controler, didnt want it on there incase it was too high so put the normal pipe back on,
am i better off putting it back on maybe its the oem pipe causing this?
i was told it was set at 20psi and re jetted to suit
if ive put the oem vavum hose back on and running stock levels would this cause mid range in boost hesitation if its jetted to 20psi?
if i drive qauter throttle it dosnt hesitate, only does if w.o.t
also noticed bov isnt working and im getting compresser surge which isnt good!
took vacum hose off and reved it and there was no vacum once throttle off, maybe bov is buggerd, or vacuam hose blocked?? im not sure how much vacum is suppose to be there!
also brake lights are not working, but was working before changing loom over maybe a relay?? tested switch works fine
checked bulbs by turning them 180 and re inserting in to bulb board
any other things to consider
and what realy is the rear brake lights (if there is a relay for this switch)
just to note indicators, reverse, fog and tail lights are working
and one more qestion (easy one if you know) whats the incraments on the boost gadge???
this is all thats wrong now and im realy hating this hesitation thing
cheers mat
« Reply #1 on: 09:53, Sat 04 April 2009 »
Depends how the carb has been setup, if it's had a large main jet fitted the that might be the cause for the awkward driving, especially at W.O.T because it will overfuel.
r5gttraider
« Reply #2 on: 09:58, Sat 04 April 2009 »
so whats my first port of call this morning?
open carb and look what jets??
or shall i replace fuel filter and put boost controller on??
also how does the turbo gaudge markings work?
« Reply #3 on: 13:11, Sat 04 April 2009 »
this will let you know the standard boost guage stages
http://www.renault5gtturbo.com/maintenance.htm
« Reply #4 on: 14:09, Sat 04 April 2009 »
A replacement fuel filter is recommended, especially if you don't know how old the one fitted is. It's not expensive and simple to replace.
As for the carb jets it depends on how much boost you want to run, but it would be a good idea to have a look at the size of the jets just so you know whats fitted. You will need a set of precision drill bits for this because they might have been drilled already and the size thats stamped on them (if they even have been marked) wont mean a thing.
« Reply #5 on: 14:30, Sat 04 April 2009 »
What boost you running ??
Hesitation @ WOT will be fuel starvation IMO.
r5gttraider
« Reply #6 on: 15:34, Sat 04 April 2009 »
not sure mate it was dark, and no dash lights as dimmer switch wasnt fitted, so im checking today
already got filter and im routing dv to the aei vacum house
as i think the dv was is routed wrong ill get a picture
what else would cause this?
r5gttraider
« Reply #7 on: 18:33, Sat 04 April 2009 »
ok put boost controler on but had boost leak out a shite dv
so changed the dv and then got no boost like itnition was cut when on throttle and boost spike. so turnt it down but then got back fire
and dv still not activating
the dv is connected here
is there any way the diaprhame is buggered? or been put back together wrong??
as theres no vacum from it after boosting and shuting throttle
so ive gone from hesitation to boost leak and now back firing lol
« Reply #8 on: 19:07, Sat 04 April 2009 »
:oops: umm my only excuse is it was late wen i replied to ur other thread last night an said rear left of the carb because i ment right sorry. ill get u a pic now
« Reply #9 on: 19:19, Sat 04 April 2009 »
its the lower of the 2 blue pipes that the dv is plumbed into
r5gttraider
« Reply #10 on: 19:20, Sat 04 April 2009 »
nice one
ok result
no boost leaks
put stock acuater pipe on and is running 9psi approx
pulls no smoke but still no dv so im getting masive lag
r5gttraider
« Reply #11 on: 19:22, Sat 04 April 2009 »
cool
ill see if that fixes it, as much as i love compresser surge sound i prefer the dv sound!!!
thanks owe
i owe u one
sorry couldnt help myself  :lol:  :P
« Reply #12 on: 19:37, Sat 04 April 2009 »
You have the d/v vaccum on the wrong hose by the looks of it, get a better pic of the engine just so i can make sure.. pretty certain you have t'd into the wrong hose, the d/v tees into the pipe from AEI to carb base on the right as you are looking at the engine, it looks like thats t'd into the left of the carb..
r5gttraider
« Reply #13 on: 20:53, Sat 04 April 2009 »
na tried the aei vac pipe made it oppen on idle, and nade it boost leak
and thats t'd to the diaprahme thats controled by the butterfly rod, and this dosnt open the dv
is the second hose down like owe said right?
cheers
« Reply #14 on: 21:02, Sat 04 April 2009 »
yes it is the lower one like i said that goes to the aei an ur dump valve shud be open on idle, wen u rev the car it will close
