Author Topic: lewlew R5 GTT  (Read 9191 times)
lewlew
« Reply #15 on: 16:07, Thu 26 February 2009 »
Dont know really about coolant light,it lights when the engine warm up to working temperature,and dont know what it means.Radiator fan switch is manual,some problems in wiring and in time i will fix it.
5 GTT
11 GTT
« Reply #16 on: 16:57, Thu 26 February 2009 »
If the guage is correct, then there is a fault with the warning light. But i would double check first.
I wouldn't be to concerned with the temperature, mine get's to that 3rd line when idling (it's only 90c) then the fan kicks in. I also noticed the temperature dropped back down when it was going along so that seems ok.
lewlew
« Reply #17 on: 17:02, Thu 26 February 2009 »
The same is to me,i have fitted low temp themostat.
5 GTT
11 GTT
Peter Ciganyik
    • http://www.rtoc.org/boards/member.php?u=261
« Reply #18 on: 01:47, Sat 28 February 2009 »
Nice five :wink:good luck
lewlew
« Reply #19 on: 10:37, Wed 08 April 2009 »
After some updates like a bigger bore one piece downpipe got 200 bhp ant 260 nm ,soon will be added dyno sheet
5 GTT
11 GTT
« Reply #20 on: 20:43, Thu 09 April 2009 »
200bhp  ...  happy days! is that still with the t2/t25?  nice car ...I like all the new parts you have added..  revs very nice too!  ;)
lewlew
« Reply #21 on: 21:24, Mon 04 May 2009 »
some fresh photos :
bought new wheels Renault speedline
Got the lowering springs -35mm at last
Stainles steel downpipe :
Both new original lamps :
Dyno sheet before and after SS downpipe instalation :
5 GTT
11 GTT
lewlew
« Reply #22 on: 11:07, Wed 06 May 2009 »
i think that i need a T25 turbo :o also i want to fit adjustable vernier pulley becouse have already fitted performance camshaft.
5 GTT
11 GTT
lewlew
« Reply #23 on: 14:48, Sat 09 May 2009 »
after front suspension updates got some drop :) (aprox 35-40mm)
5 GTT
11 GTT
lewlew
« Reply #24 on: 19:44, Sat 09 May 2009 »
5 GTT
11 GTT
« Reply #25 on: 19:57, Sat 09 May 2009 »
Looks good. You need to lower the rear though :D
lewlew
« Reply #26 on: 22:16, Fri 15 May 2009 »
Speedline wheels fitted at last
5 GTT
11 GTT
« Reply #27 on: 04:08, Sat 16 May 2009 »
lovin them wheels mate 8) just have to get that rear beem lowered and she look the nuts 8)
lewlew
« Reply #28 on: 07:12, Sat 16 May 2009 »
ye,its in my plan :)
5 GTT
11 GTT
lewlew
« Reply #29 on: 21:05, Fri 22 May 2009 »
turbo outside
5 GTT
11 GTT
