Author Topic: Tune my GT TURBO!!You tell me what and I will do it!!!  (Read 3814 times)
CroHunter
« Reply #15 on: 22:43, Fri 16 January 2009 »
I have few motors in parts..must put one together...so what must I look for i what can I do for tuning on them to get more power???come on folks help me!!!!!!!!
« Reply #16 on: 22:50, Fri 16 January 2009 »
cam's ,Turbo's, super chargers, nos, induction kits , flywheels , lsd, forged pistons, bigger valves, bigger injectors if allready got injection or make a injection system for a 5 turbo, there's loads of options
CroHunter
« Reply #17 on: 20:35, Sun 18 January 2009 »
hmmm..I'm a liitle weak with english.this will be hard..
CroHunter
« Reply #18 on: 20:39, Sun 18 January 2009 »
cam's (what is a cam?is this a carburator???)
 nos(don't want it for now),
induction kits (what are they for)?
flywheels(where are that parts?)
lsd, forged pistons(what are these?)
bigger valves (ok that is what i understand.which can I use?)
bigger injectors if allready got injection or make a injection system for a 5 turbo --how to make this?[/b]
« Reply #19 on: 20:48, Sun 18 January 2009 »
Quote from: "CroHunter"
best to do a search in www.google.co.uk and you'll find everything u will need
« Reply #20 on: 22:08, Sun 18 January 2009 »
Cam - Camshaft, lumpy stick that open/closes valves. Different types have different lift and duration.
Induction Kit - Not needed, turbo cars = forced induction so whats the point? Just a well placed air filter, even the standard one is good.
Flywheels - You can shave some weight off to help the engine rev more freely.
LSD - Limited Slip Differential, Stops just one wheel from spinning in the corners. Absolute nightmare on the road in my opinion.
Forged pistons - Pistons that are forged.  :lol:  Stronger then standard items.
Bigger valves - Usually it's just the inlet valves that need to be made bigger, but i only have done this on a different engine so have no idea on the R5 engine, maybe someone else can help?
Injection - Hmmm, lots of information needed for this one. Basically you can modify the inlet manifold to fit injectors, then run these from an aftermarket management such as Megasquirt, Emerald etc.
