Author Topic: Jet Black 5 turbo  (Read 9522 times)
« Reply #45 on: 21:31, Fri 24 April 2009 »
that it did, that it did :D
Plus i plan on taking it to uni with me, and the last time my mate took his car up with a hole in the bonnet some c***s cut his fuel hose and threw a fag in, luckily it had no fuel at the time :D
So it keeps prying hands out from under
« Reply #46 on: 19:26, Fri 22 May 2009 »
Quick update on the car.
The rust is going well, apart from the sheet metal i put ontop, the rust on that is the rust i want all over, it doesnt seem to want to though.
I also had an oil leak, turned out to be my rocker cover gasket, im in the process of shining the cover up and putting it back together, and beating out the dents in it.
Doing the tappets at the same time also.
DanielSon-gtt
« Reply #47 on: 19:46, Fri 22 May 2009 »
why are you going for a rusty bonnet look..?
Go Boost Or Go Home
« Reply #48 on: 20:32, Fri 22 May 2009 »
I had an ugly ass bonnet scoop on it, and when i took it off it had a huge hole, ive always wanted a rat look car and i thought what better opportunity than on an already destroyed bonnet :D
DanielSon-gtt
« Reply #49 on: 21:00, Fri 22 May 2009 »
true true
Go Boost Or Go Home
« Reply #50 on: 18:42, Sat 23 May 2009 »
Ok so i did the tappets and rocker cover today,
Beat out the dents.
I love things sprayed in primer :D
All sprayed up in satin.
Tappets done.
All back together.
Ticks over like a swiss watch now ;)
LEE
  • Administrator
« Reply #51 on: 19:54, Sat 23 May 2009 »
Nice job on the rocker cover !!
Site Administrator
« Reply #52 on: 16:49, Mon 25 May 2009 »
Thanks man.
Had to fix my cold blower today, it had snapped off the bracket.
