Author Topic: My Phase 2 R5 GTT  (Read 2766 times)
Tom@SimplyAutomotive
  • Trusted Trader
My Phase 2 R5 GTT
« on: 23:49, Tue 23 September 2008 »
This is my 1990 Phase 2 Renault 5 GT Turbo.
This is my car at the moment, as i bought it.
Engine
B&M Short Shift
Helix Paddle Clutch
Piper 285 Cam
Samco/SFS Hoses
Uprated Valve Springs
Gasflowed Head
Group A Carb
Hybrid 200 Turbo (from looking at the reciept)
Braided Turbo Feed
Exterior
Carisma Spoiler
Quad Fog Lights Front Bumper
Rear Bumper
Interior
Origional Interior
Oil Pressure
Turbo Boost Gauge
Chassis
Polybushed
Lowered
« Reply #1 on: 23:53, Tue 23 September 2008 »
Ah, i see the good ol haynes bible sitting on her, don't worry, soon enough you won't need it if you're keeping her... i know most of it by heart & a few tricks it doesn't mention. lol...
Get that fuel out or at least test the fuel like i said with the jerry can & pipe to pump ;)
smudger
    • http://smudger.fotopic.net
« Reply #2 on: 08:31, Wed 24 September 2008 »
8)  8)
  • Trusted Trader
« Reply #3 on: 14:19, Thu 25 September 2008 »
Things ive got to do.
Change starter motor -done
Change flywheel - lightend and balanced
Clean out fuel tank/flush fuel pipe
Clean engine, gearbox and engine bay
Clean Carb
Fix Bumper
Fix Bonnet
Change Drivers side wishbone
Change drivers side driveshaft - done
Change steering rack - done
Change water pump and gasket
Change boot (bit rusty on seals)
« Reply #4 on: 15:03, Thu 25 September 2008 »
Won't take long to sort all that, fuel tank is worst job  :evil:
« Reply #5 on: 17:11, Thu 25 September 2008 »
Followed closely by the wishbone. Far easier to change the whole thing rather then struggling your balls off trying to push the old bushes out.
  • Trusted Trader
« Reply #6 on: 17:18, Mon 29 September 2008 »
Started to clean the gear box.
« Reply #7 on: 21:45, Mon 29 September 2008 »
Looking good matey, just take your time with itso at least you know when it all goes back together that you have done everything correctly.
Look forward to seeing it about on the roads. :D
« Reply #8 on: 22:23, Mon 29 September 2008 »
That box looks alot cleaner than when i last saw it, what are you cleaning it with ??
Also did you get a new wishbone yet, if not don't forget to get it with the bushes pressed out if you get it from Bob, then you can fit the poly's straight in as they're easy ;)
  • Trusted Trader
« Reply #9 on: 22:09, Thu 02 October 2008 »
Im using GUNK to get most of the dirt off and then BRAKE CLEANER to get the rest off.
I havent got the wishbone yet, im going to order it and a few other bits on Monday.
« Reply #10 on: 20:32, Fri 03 October 2008 »
Hi Tom,
You got it up and running yet :?:
« Reply #11 on: 17:48, Mon 13 October 2008 »
Quote from: "4364_James"
Hi Tom,
As above....
  • Trusted Trader
« Reply #12 on: 23:49, Tue 14 October 2008 »
Hi Guys,
Ive been really busy at work and havent had much time in the last couple of weeks to get the car running.  :(
Im hopefully going to order the last few bits either this weekend or next.
I sold the spoiler and relised that i now need a new boot because my ones full of holes.... :(
Hopefully i should have it finished at the end of November. :)
« Reply #13 on: 09:25, Wed 15 October 2008 »
Campus one will fit if you can find a GTT one, you will have to stick the spoiler on though, or run without one :)
  • Trusted Trader
« Reply #14 on: 16:01, Sat 18 October 2008 »
I have decided to stop the project at the moment because of work being busy.
I am thinking of selling the car in bits or as a hole car?  :(
And then getting a running one that is ready to go on the road.
Its a shame really because i really wanted to get it running but due to work i have no more time to spend on it at weekends.
Thank you to everyone including Steve and James who were a really big help. Cheers! :)
