Author Topic: New paint! R11 Turbo from Finland  (Read 7269 times)
Theros
« Reply #15 on: 17:39, Mon 15 September 2008 »
I painted engine and other smaller parts in silver. It is not ready yet, but good start :) :
Clutch :). That clutch should be able to keep easily 220 hp (guaranteed) :
More:
Some parts:
Theros
« Reply #16 on: 17:40, Mon 15 September 2008 »
Then from other side:
Theros
« Reply #17 on: 17:49, Mon 15 September 2008 »
I will post more soon :)
« Reply #18 on: 18:14, Mon 15 September 2008 »
I've added the pictures to one post for you. Nice heatshield  8)
Arturas-zender
    • http://www.emusic.lt
« Reply #19 on: 18:57, Mon 15 September 2008 »
good work friend  :wink:
« Reply #20 on: 19:13, Thu 18 September 2008 »
coming along nicely there mate,is your bottom end standard or have you been in about? shell be cool when shes done 8)
Theros
« Reply #21 on: 19:32, Thu 18 September 2008 »
I rebuild whole engine...there are still standard pistons, standard cranckshaft...bearings are better than normal.
I changed all seals etc...valve adjustments were quite interesting...lol...there are maximum size valves.
BTW: If you guys want change cylinder head, then you should look also Twingo's cylinderhead. There are already larger valves and it is "bolt-on" to c1J engine.... ;) ....
« Reply #22 on: 19:45, Thu 18 September 2008 »
aaaah didnt know that,are you refering to the old twingo,we didnt have much of them in britain,ill keep that in mind for future projects  :lol: if  the wife will let me,keep up the good work
Theros
« Reply #23 on: 19:48, Thu 18 September 2008 »
Hehe... I fitted R19 16V radiator fan (I don't know if it is right word)...it is bolt-on too.
It don't keep as much noise as original (similar to R5 GTT radiator fan)...
I have also front axle from R19 16V...that way there are bigger discs (better brakes) and axle is stronger also...it was "almost" bolt-on...
« Reply #24 on: 22:35, Thu 18 September 2008 »
thats great you can fit other parts from similar models 8)
Theros
« Reply #25 on: 17:07, Sun 21 September 2008 »
OK folks....time update little bit.
I painted gearbox today, but it is not ready yet so...I will post pictures later :) .
Here are some parts... :) ...those will be installed immediately after painting...
New steering wheel :)
Minor tube to my T25
New inlet manifold...little bit larger and some other mods...
Little bit update to security:
smudger
    • http://smudger.fotopic.net
« Reply #26 on: 17:18, Sun 21 September 2008 »
You have been a busy boy. I really like the steering wheel. Where did you get it from mate if you don't mind me asking?
AudioPStar
« Reply #27 on: 17:22, Sun 21 September 2008 »
I too quite like the steering wheel and my 5 could do with a new one.
Theros
« Reply #28 on: 18:26, Sun 21 September 2008 »
Quote from: "smudger"
I bought that from eBay...from Poland I think...
Just try to find Steering wheel and Renault ...
Theros
« Reply #29 on: 19:54, Tue 30 September 2008 »
Ok...time up update. I received more parts and gearbox is now finished (pictures from that later)...
New bulbs :)
Necessary wires to use safely remote start.
Adjustable fuel pressure regulator with gauge...
I will receice soon 7 bar fuel pump to replace old one...  :D
