Author Topic: 200 hp HOW?  (Read 1628 times)
john29
200 hp HOW?
« on: 19:01, Sun 08 June 2008 »
What do i need to go close to 200hp?
I may be up to 170-180hp ( am i ? ) from what i see from similar configs.
My current specs are
T25 turbo .48 front,360 thrust
Twin core alloy IC
samco boost pipes and alloy lobster elbow
60mm stainless steel full exhaust system+downpipe
KTR leads
rejetted carb 145 main
omp cone filter
external breather system
cup mode
uprated cooling system ( cooper rad. ,switch etc. )
 20psi boost
intenals pistons,gasket, etc all standard
« Reply #1 on: 20:01, Sun 08 June 2008 »
From your spec you could be close, it really does depend on your turbo, a cam will also help as it will rev higher & freer. Also the cooler may be on the limit & a 145 main jet is over kill as well.
I made over 200bhp, have a look at my spec, it's at the bottom in my sig, just click on it & have a read of what i've done to get there.
john29
« Reply #2 on: 21:37, Sun 08 June 2008 »
i saw your spec and you are using the piper 285.Does the vernier and the springs really neaded?What about an exhaust manifold like KTR's?
Do you think the standard pistons are good for such boost?
lexgtturbo
« Reply #3 on: 21:46, Sun 08 June 2008 »
I dont think the pistons is anything to worry about before you want a bit more than 200bhp
« Reply #4 on: 21:47, Sun 08 June 2008 »
If the fueling is set up right then 20-21 psi is ok on standard internals, yes you do need the high lift springs or you run the risk of going coilbound at high rpms, the vernier is only needed if the cam isn't ground well (mainly due to being a regrind) as it can be a few degrees out, if it's a blank then it should be close enough with the standard sprocket.
KTR manifold, as in the tubular ?? Waste of money in my opinion.
HTH
Steve
john29
« Reply #5 on: 22:06, Sun 08 June 2008 »
ok thanks lads i got the point! :D
