Author Topic: My Phase 2 GTT  (Read 60378 times)
RickGTT
« Reply #30 on: 17:56, Sun 11 February 2007 »
so u would say its a worthwhile investment to buy one
theres a little 5 in all of us
« Reply #31 on: 18:09, Sun 11 February 2007 »
Like i say its down to preference really,alot of people go for LARGE FMIC,(which in the winter suffer from carb freeze),you only need something say the size of a cozzy 4x4 cooler,bigger isn't always better,the other reason people prob go for FMIC is the cost,say 250 against 600+ for a chargecooler,i prefere the chargecooler,but as i say the test will be in the summer when its much hotter.You can always run an intercooler with the chargecooler :D
BNZ
    • http://roadrunners.ro/forum/viewtopic.php?t=1283
« Reply #32 on: 18:19, Sun 11 February 2007 »
Yeah,carb freezing...me,tested,true !  :lol:
The problem ocures only on the long road,in the city,there is no problem
The easy solution is a piece of carton from a box,put it in front of the intercooler,and stop the airflow trough it ! :D
« Reply #33 on: 22:25, Thu 15 March 2007 »
UPDATE
Saftey devices rear cage in now & stripped the rear out,removed the sound deadening under the carpet as well,fitted the rear suspension,got an Apexi AVC-r to control the boost,MB performance downpipe/elbow combo is here & will be fitted by the weekend,got to fit the front coilovers & get her ready for Santa Pod on the 25th March where i hope to get into the 13's :D  gonna be running 1.5 bar boost & dunlop inferno road legal drag tyres.
Was hoping to get her on the rollers before pod but i don't think thats gonna happen till after now.
BNZ
« Reply #34 on: 08:45, Fri 16 March 2007 »
How mutch does the sound dreadening from under the carpet weight ?
Put some pics with the performance downpipe/elbow pls !
« Reply #35 on: 10:36, Fri 16 March 2007 »
Well the sound deadening weighs quite a bit(especially as mine was wet!!),makes for a slightly noisier road car but like i say it does weigh a bit.Trying to decide weather to take out the plastic in the rear as well,all things that aren't needed are being stripped for Pod. :D
Here's the downpipe next to a standard one.
on its own
Downpipe cost me 301 euro's delivered from the Netherlands to GB
BNZ
« Reply #36 on: 16:52, Fri 16 March 2007 »
God'damn...301 EUROS ? for a piece of...pipe ?!  :shock:
I am shure selling my 1.6 conv kit to damn cheap :lol:
Btw. regarding weight,the rear plastic weights next to nothing,i removed them allso but only for rattle reasons.
U can take the rear wiper and the motor down,that's around 2kg,and important,take the grill that holds the spare tyre,off completly allso around 2-3kg!
P.S. Anyway the downpipe is great,i will steal some manufacturing ideeas for my own remanufactured exhaust ! :P
It look's like a 60mm diameter ! Or am i wrong ?
BNZ
« Reply #37 on: 16:53, Fri 16 March 2007 »
..error
...to br deleted (this post)
« Reply #38 on: 18:58, Fri 16 March 2007 »
Quote from: "BNZ"
..error
Its 2.4 inch but if you're making one it could be whatever size you want  :D
Thanks for the weight saving tips,forgot about the wiper motor.
« Reply #39 on: 20:55, Fri 27 April 2007 »
Fitted the downpipe & coilovers,got a tarmac rear spoiler to fit & i also bought one of these to tune my carb properly http://www.innovatemotorsports.com/xcar ... t=0&page=1
Will be down at Santa Pod 1/4 mile on the 12/13th May,so we'll see what times i get :D
« Reply #40 on: 22:01, Wed 02 May 2007 »
Carb spec & results so far;
Spec;
1.3 main jet
1.1 air corrector
1.0 1st stage
1.1 2nd stage
AFR results after adjusting mix screw on idle
idle 14.5-15.1 (lumpy cam i reckon,although it may be jetting)
Light throttle 10's which is way to rich
On boost 13's which is way to lean for 1.4 bar boost
So i will be putting in a 1.2 main,1.25 air corrector,leave the 1st stage & open the 2nd stage to 1.3 & see how she does from there  :D
RickGTT
« Reply #41 on: 18:44, Thu 03 May 2007 »
hows the chargecooler performing now that the weather is getting hotter?
« Reply #42 on: 10:20, Fri 04 May 2007 »
Seems ok,but my charge temp gauge has packed up!! :roll:
Im looking into getting a Mike Rainbird one to replace it soon though so i'll let you know.
RickGTT
« Reply #43 on: 18:03, Tue 08 May 2007 »
dont think i will be getting chargecooler as i just bought k-tec fmic and it looks the dogs bollocks,although its not on my car yet
« Reply #44 on: 19:04, Tue 08 May 2007 »
I must admit i've been thinking of getting a FMIC just for the look  8)
