Author Topic: Romanian GTT  (Read 41531 times)
BNZ
    • http://roadrunners.ro/forum/viewtopic.php?t=1283
Romanian GTT
« on: 14:13, Sun 31 December 2006 »
My engine :
Low compresion pistons
R11 camshaft
T25 SAAB turbocompresor
Megane 2 dCi front-mounted intercooler
RE037 ECU
External Oil Cooler
G-Tech measurements @ 860kg(me included) and 1.2 bar:
0-100:6.67s
0-400:14.7
Movie Archive:
Important Victim's
Play'n around
P.S. to bad i can't add pictures directly in this forum...
Goran
    • http://www.bhrenaultclub.com
« Reply #1 on: 09:26, Wed 03 January 2007 »
I would love to see the some pictures.... it's a nice setup... you can always use www.photobucket.com to upload the pics... :wink:
BNZ
« Reply #2 on: 13:27, Wed 03 January 2007 »
BNZ
« Reply #3 on: 00:08, Sun 14 January 2007 »
Quote from: "GTTBoy"
1.6 what did that come out of??
I have custom made pistons Bore 77 and a semi-custom made Crank with 83.4 stroke !
Compresion Ratio 8.1 : 1 on 1598 cmc with stock R5 2mm gasket and re-styled combustion chambers !
I'm still thinking with what type of turbo to charge this engine...i have a new T2 and a second T25...more middle range power versus top end power...hmm :?
And this is my work in progres :
Tomorow,after i polish the comb. chambers i will take some pictures to show u what i mean...maybe u steal some "low compresion" ideeas !  :twisted:
« Reply #4 on: 17:44, Sun 14 January 2007 »
Nice..i hope it lasts,sounds like you've put some time & money into it,money pits the GTT's are......keep us posted :D
« Reply #5 on: 18:33, Sun 14 January 2007 »
One unique GTT is on its way 8)
« Reply #6 on: 18:55, Sun 14 January 2007 »
Quote from: "BNZ"
Yes please, more R5 GTT porn :lol:
BNZ
« Reply #7 on: 19:22, Sun 14 January 2007 »
I've found here a 84 Stroke Crank for the R5 at a troumenduos breath-taking pice... 1.945, 00EUR
I can suply you with the whole 1.6 UPGRADE KIT including:
83.6 NEW Crank
77 Bore NEW Pistons (including new cilinders and the thing that hold's the piston on the rod)
NEW STD Kolbenschmidt Connecting rod bearing Set
NEW Kolbenschmidt STD  Crank bearing Set
at ONLY *** Euro
Everithing will be made ready to fit,no further modifications necesary.I know now the recepy
The compresion will remain 8:1 as in standard 1.4 engine with you'r std 73.4 CilinderHead and standard HeadGasket.
An so u have a BRAND NEW 1.6cmc engine setup,that theorethical,will deliver at standard boost (0.65bar) 140 HP.Imagine this as a base for overboost ! ;)
P.S. I reckon,this setup will take me to around 160 - 180Hp @ 0.95 BAR from a T25,and i have a stock camshaft,but the bigger increase will be at the other side...the torqe ! Bigger stroke means a more torque engine so in the quarter-mile run this i hope will make a big difference !
P.P.S Hope that's porn enough for now ! :lol: Still more to come...
« Reply #8 on: 19:55, Mon 15 January 2007 »
Impressive mate! Massive respect 8)
Why do you use "safety" screws to hold piston followers?
BNZ
« Reply #9 on: 21:06, Mon 15 January 2007 »
Quote from: "jure"
piston followers = the cilinders ?
In that case is simple...if i rotate the crank,the followers are pushed outside the engine bloc.
And after u tighten at torque the crank-holding screws,and the piston-rod screws it's important to check how it "flows".
If it rotates hard than something is not good,and the worst is,if u have a damaged piston-rod (i've had sutch an experience on my other car,same engine after mashing up a piston-rod bearing...see pics)
After the race with a Honda HRV 4x4 with my other car,a Dacia(R12) with GTT engine :
During hard acceleration,oil-pump cought air,preasure instantly dropped and...
« Reply #10 on: 21:16, Mon 15 January 2007 »
OK got you point. I do not have those on mine coz followers (cilinders) have more flat surface than yours- one touching next follower so there in no chance of rotating and used glue for metal and put it between folower and the block. But had bum with followers hitting the head. The head wasn't polished properly (not flat) and one follower was hitting the head and my gasket blown :oops:
BNZ
« Reply #11 on: 21:27, Mon 15 January 2007 »
They all have flat sides,so they do not rotate...
And yes,only thing that hold's them in place is the gasket's ring...
Nasty if you're head was not plane,i suppose u were not long on the way until next blow :P
Once i had a custom made 2.5mm gasket coverd in copper (but the ecu's vacuum vas damaged and i had massive detonations) put it on,drive one straight line at 0.8bar and...more porn :lol: :
« Reply #12 on: 23:16, Mon 15 January 2007 »
Nice :lol:
Some people are filling gas on weekly basis and you, seam to me, are changing gaskets :P
My friends are teasing me all the time but i tell them that i do not need water injection coz my pistons are water cooled :D
BNZ
« Reply #13 on: 02:04, Tue 16 January 2007 »
LOOOLOOOZZZZ...that's a good one !!!  :lol:  :lol:  :lol:
Advancing...
Re-designed compresion chamber
Light Flywheel
New Blak-Ferodo rebuild clutch
« Reply #14 on: 11:20, Tue 16 January 2007 »
I see you have modified the 'squish' area by having flat top pistons & a modified head,also bigger valves as well,can't wait to hear the results you get from it. :D
How the heck did you blow a copper gasket :shock:  must have very strong liners
