Author Topic: Renault super 5 project from Slovenia  (Read 15499 times)
jero_13
« on: 20:31, Tue 03 July 2012 »
hi this is my little project. it started live as a R5 Campus, and now she will get a engine transplant and a suspension upgrade. on the to do list is a front adjustable suspension and a widetrack swap from a clio williams, rear suspension upgrade from a clio mk1 cup racing car, full 9-point sparco rollcage, full racing interior and a 1.6e megane engine swap. also on the to do list is a flocked clio 16v dash and wiring loom. this car will be a pain staking job to do but she will be something else when she is done :)
and now the pictures :)
my inspiration is a photoshop i made, this is roughly how she will look like when she is done:
and here she is:
front bumper in desperate need of someTLC
Engine redy for implant :)  ( tuned 1.6 K7M engine (115bHp) )
wheels
Rollcage
Steering wheel
Rear suspension (needs some paint)
Racing seats
and donor of parts
Comments and opinions welcome :)
p.s. sorry for my bad english.
compact
Re: Renault super 5 project from Slovenia
« Reply #1 on: 07:40, Wed 04 July 2012 »
Interesting project! :wink:
nick1983
« Reply #2 on: 18:23, Mon 09 July 2012 »
i think your English is excellent, if you manage to get that done it will be superb and your photoshopping skills are superb.
270 cam
Modified carb, large venturi
2.5in downpipe
large elbow
2.5in side exit
Paceintercooler
samco blue hoses
Green induction kit
T25 turbo
Forge actator
jero_13
« Reply #3 on: 10:39, Tue 10 July 2012 »
Thanx mate.
I only have one question. Does the williams widetrack fit on the five? Has it been done before? Because i'm a little affraid it will be too wide. Any ideas?
The plan s to have it drivable in 2-3 monts :) i'll keep you posted on the progres :)
gt alan
« Reply #4 on: 13:06, Tue 10 July 2012 »
I'm liking the look of this project  :!:  Hope all goes smoothly.
I've got a question tho. What is the difference between them white speeplines and willie wheels?
Alan
jero_13
« Reply #5 on: 14:38, Tue 10 July 2012 »
Quote from: "gt alan"
I've got a question though. What is the difference between them white speeplines and willie wheels?
Alan
Thanx mate.
Those are willie wheels painted white and speedline stickers on them :)
jero_13
« Reply #6 on: 11:53, Thu 12 July 2012 »
this has just come in :) it's the adjustable front suspension from Koni :D Som mods will be required since they are for a mk2 clio but i think it will work.
and some adjustable billstein rear dampers:
(in comparison to a OEM williams damper :) )
jero_13
« Reply #7 on: 21:43, Sun 15 July 2012 »
And she is finaly on all her 4 wheels.
Fitted thesubframe, wishbones and dampers from a clio. it was almost a straight fit. you just have to modify the front right hole on the subframe.
the car is finaly ready to go to my place so it can get worked on :)
jero_13
« Reply #8 on: 20:42, Sun 22 July 2012 »
in the las couple of days i have worked on my little 5 a bit :)
I stripped out the dash and all the interior wiriing, since clios loom and dash are going ino the car :) then i managed to modifie the clios engine bay loom to fit the R5's lights and side repeaters. the car needs a good washing and the subframe needs some degreasing :/ currently i can't do much work becase the bad weather :(
But since it was raining i had a little time to play in fotoshop and this is what came out :)
jero_13
« Reply #9 on: 18:23, Tue 24 July 2012 »
me again :D
today i've started on the dashboard :)
stripped & test fitted
It still needs quite some mods to fit :)
and some other photos of the car :)
empty space fot the engine :D
« Reply #10 on: 21:37, Tue 24 July 2012 »
Looks like an interesting project. I like your Photoshop images.  8)
jero_13
« Reply #11 on: 14:12, Mon 30 July 2012 »
thanx mate :)
jero_13
« Reply #12 on: 10:15, Sun 20 January 2013 »
So tthe 5 project has moved on  bit.
The new front bumper :) She finaly looks as she shuld :) Since then i'have fitted the GTT front fenders, so the flares will fit perfectly. i just have to put the flares back together as they are in quite a bad nick.
The engine on a mk1 clios subframe, with wishbones from a mk1 megane, so the track is as wide as a Williams.
Because i did not have any sensors for the original 16v gauges, i have modified them so the holder fits the aftermarket gauges. This is what i have came up with:
And i have got the new wheels for the little five. Because RETRO is how we roll
jero_13
« Reply #13 on: 09:14, Thu 04 April 2013 »
hi guys, i'm sorry for the delay, but i have been very busy.
Ok now the fruits of my labour :)
I have decided, since this is a racing car, I am going with the hydraulic handbrake, but i wanted to keep the original handbrake leaver. This is what came out:
and mounted:
Then we started to work on some camber adjusting top mounts. This was a pain staking job. But i have persevered and made this:
and finished:
After that i focused on the suspension:
Front subframe from a clio cleaned and de rusted:
All welded up and test fitted the widetrack from a megane. the stabiliser bar was too long so it was trimmed to length later.
Primered
Painted:
And assembled:
Then the rear suspension from a valver was fitted:
And the front:
And i have managed to find a perfect back box for it too:
jero_13
« Reply #14 on: 19:11, Mon 15 April 2013 »
Sparco seat mounted
Engine inside :)
Dash
Mounted inside the car
different wheels
