Author Topic: Back in the Game :) well not a GTT but still it's a Renault  (Read 13207 times)
Re: Back in the Game :) well not a GTT but still it's a Renault
« Reply #15 on: 11:46, Tue 13 March 2012 »
« Reply #16 on: 23:20, Tue 13 March 2012 »
That engine bay looks even smaller then that of a 5.  :shock:
« Reply #17 on: 08:57, Wed 14 March 2012 »
To be honest Ash there isn't much difference, the bulkhead holes are alot smaller than a 5, the good thing with the clio is the front slam panel is bolt in  and bolt out and makes things alot easier to work on at the front.
Space wise overall it's bascially the same as a 5
hughesrobert13
« Reply #18 on: 21:21, Wed 14 March 2012 »
im modding the slam panel on my 5 so it can be unbolted, seen it on alot of rally cars etc just makes life that much easier  :lol:
Every day is a school day !
« Reply #19 on: 21:59, Wed 14 March 2012 »
Quote from: "hughesrobert13"
Definatly, I done the same to my old 5gtt whe I don the f7p turbo conversion made such a difference
Dave
« Reply #20 on: 23:46, Sat 17 March 2012 »
james the clio is coming up really well mate.
hughesrobert13
« Reply #21 on: 20:58, Wed 21 March 2012 »
Quote from: "James5"
do you have any pics of how you done it ? i havent started chopping it up yet i want it to look as oe as possible so its got to look like its meant to be there.  :wink:
« Reply #22 on: 22:05, Wed 21 March 2012 »
 :lol: Sorry no pic's of i, I literally got the angle grinder and cut it then I cut some holed metal bar and drilled 2 holes in the now removable section and used 2 x 13mm bolt and nuts on it and and drilled 2 holes in the sections on the car I didn't cut and then just bolted the bar up looked fine barely noticed it was cut. Steve aka 5teveL done a similar thing
hughesrobert13
« Reply #23 on: 21:03, Thu 22 March 2012 »
i was goig to use a scrap gtt i got and cut it so i can use it to overlap my slam panel so it will hopefully look quite tidy. i suppose you will hardly see it with the way the bonnet opens though
« Reply #24 on: 13:18, Mon 26 March 2012 »
« Reply #25 on: 10:28, Tue 27 March 2012 »
Well had a little play with the clio again last night and done the following:
Started the car for the first time since I have owned the car after engine re-assembly and it worked fine  :mrgreen: other than the exhaust rattles like hell on idle and has a blow
Replaced passenger side headlight due to stone chip,
Replaced drivers side front indicator due to crack,
Replaced steering wheel with working leather airbag version (safety first)  :lol:,
started removal of sun roof so can sort leakage out,
Need sunroof electric controls and possibly motor would like to get it working,
Considering Vinyl wrapping the roof myself with carbon fibre effect vinyl like my old GTT
« Reply #26 on: 20:08, Mon 02 April 2012 »
James. Glad your finding your feet again ! Interesting read, as I've been offered a clio RSI , I just wondered what's the cost of the running kit involved to turbo charge that lump.
Then again I know my way around the. 5GTT engine fairly ok so consider this to be a big possibility, is there majour drama dropping in the gt lump, is it straight forward?
« Reply #27 on: 07:54, Tue 03 April 2012 »
Quote from: "r5matt"
Clio 5 same thing really other than the 5 looks  8) , the more I do with the clio the more I realise it is so similar to the 5 other than engine being main difference.
Depends which route you go me I am trying to do it as cheap as possible this time around and therefore just need to get the standard pistons skimmed for low comp, and I intend to use standard ECU but get it mapped for turbo I am hoping to spend around 2k max
« Reply #28 on: 08:31, Thu 05 April 2012 »
Now breaking the valver for parts due to lack of enthusiasm for the valver
« Reply #29 on: 12:52, Thu 31 May 2012 »
:lol:  No longer back in the game stripped the car to a bare shell and it's now gone to car heaven
