Author Topic: T25 actuator  (Read 1228 times)
john29
T25 actuator
« on: 11:35, Sun 01 January 2012 »
Hi, does anyone knows how much you can shorten the actuator arm  on a T25, before the actuator gets damaged?
Re: T25 actuator
« Reply #1 on: 13:05, Sun 01 January 2012 »
Don't think your damage the actuator shortening the rod alot but if your having to do it alot then it sounds like you need a new stronger actuator
john29
Re: T25 actuator
« Reply #2 on: 15:09, Sun 01 January 2012 »
i thought that i may brake the spring by shortening it a lot,there are only a couple of turns left.
Re: T25 actuator
« Reply #3 on: 20:50, Sun 01 January 2012 »
Quote from: "john29"
I don't think your break it, you'll be putting it ubder alot more tension though. As say if your having to adjust it that much sounds like you need a stronger actuator
john29
Re: T25 actuator
« Reply #4 on: 21:55, Sun 01 January 2012 »
ok,got it thanks mate!
