Author Topic: which engine would best suit track days?  (Read 1974 times)
deepee
« on: 12:31, Sun 11 December 2011 »
hi guys, recently my engine went on my 5 campus, got offerd 40 scrap so though if i have nothing to loose why not make a track car out of it, there minimal rust with SOLID sills and a solid underside!
i dont want to put a c1j engine as i dont think it would hold out to well being thrashed around a track, im most likely looking for a n/a engine
i do believe the clio 172 engine can be put in with very minimal work, just one engine mount needs changing? i assume wireing will be tricky?
if anybody could shed some light on this conversion please help me,
any advice will be appriciated, thanks
Re: which engine would best suit track days?
« Reply #1 on: 15:09, Sun 11 December 2011 »
Look what i found in the DIY section.
viewtopic.php?f=14&t=4143
That should get you started.  :D
« Reply #2 on: 13:05, Thu 15 December 2011 »
172 (f4r) engine is easy as is to install as doing the F7p / f7r and the B18ft.
All depends what you want n/a or turbo, the f4r requires a different bonnent but the f7p and f7r don't. For easyness and cheapness F7p or B18ft will prob be the options really as you can get parts so cheap.
Quite a few of us on here have done various conversion's so plenty of advice around and info in the DIy section on the various conversions
« Reply #3 on: 21:48, Fri 16 December 2011 »
If you want simple, reliable track car with minimal work to do on the conversion then i would say fit the F7P engine from the mk1 Clio 16v.
These go well in the 5 and doesn't take alot to fit plus costs very little to do
