Author Topic: Black 5  (Read 8814 times)
Jack88
Black 5
« on: 15:43, Sat 01 October 2011 »
Heres my 1988 Black Gtt
Its completely standard apart from a sunroof which means the roof is being chopped because I want it as if it rolled out of the factory
Its also quite rusty and needs a few new bits
When I got it
Stripped put what I could on the drive
Scrubbed this hard  :o
They were a bit mouldy and discoloured
Cleaned up
Tailgate is being replaced due to rust
1st refurb
Jack88
Re: Black 5
« Reply #1 on: 15:57, Sat 01 October 2011 »
Re: Black 5
« Reply #2 on: 18:00, Sat 01 October 2011 »
Wow that looks pretty serious around the windscreen  :shock:  :shock:  :| , I have the same job to do around mine now it's out although nowhere near as extensive.
Best of luck with it though, have a look at Baz's black 5.. his was probably the most rotten 5 on here and he just kept going with the repairs.. about half his car is new metal now!
cosmicrayturbo
Re: Black 5
« Reply #3 on: 21:04, Sat 01 October 2011 »
What did you use on the dash? Did you wash it with anything in particular first and then nourish/polish it with something after?
That welding looks serious, nice big workshop though 8)
If you know of any links to sites that have any info on the pearly ones, pm please.
cosmicrayturbo
Re: Black 5
« Reply #4 on: 21:12, Sat 01 October 2011 »
Did you have to replace inner and outer sills?
Jack88
Re: Black 5
« Reply #5 on: 11:27, Sun 02 October 2011 »
To be honest I probably went a bit ott on the scuttle panel grinding, although it was quite bad and decided to get rid of the hole lot. I'm looking for a donor as I can rob everything I need pretty much, looking for a campus!
I just used a paint brush and washing liquid on the dash to get into all the tight spaces then dried it & used a citrous interior polish / protector. It's come up quite nice, so much easier to do when it's not in the car
The inner seals are pretty good so just replacing the outers
Re: Black 5
« Reply #6 on: 11:37, Sun 02 October 2011 »
nice work  :mrgreen:
keep the pics coming...
Re: Black 5
« Reply #7 on: 14:01, Wed 05 October 2011 »
nice work bud ,fair bit of work on that scuttle panel aswell ,keep up the good work mate
ben marks
Re: Black 5
« Reply #8 on: 20:36, Mon 10 October 2011 »
found it ! lol
looks like your getting on a treat best way to do it cut it out  :D  no covering up going on here then, wheel looks sweet to !
Re: Black 5
« Reply #9 on: 15:04, Tue 11 October 2011 »
she was fairly rotten like  :D  :D  :D , cheers mate there 16s
gt5rob
Re: Black 5
« Reply #10 on: 17:15, Tue 11 October 2011 »
good work mate! have you had any luck with finding a donor? looks like a huge garage you got there  :lol: i wish i had one like that, im using my parents front drive  :x
Jack88
Re: Black 5
« Reply #11 on: 22:38, Tue 11 October 2011 »
im going to cover up the door seals but as for the scuttle..... its gone  :o
The garage was a bit of a result actually, it was going to go in my tiny garage but a friend of my dad has let me work in his garages. Im working on it in a spray booth, so when its ready it will be sprayed too
unfortunately im at uni so can only work on it the odd weekend  :(
Jack88
Re: Black 5
« Reply #12 on: 22:42, Tue 11 October 2011 »
donor car searching is pretty dire,
Im looking at one on ebay at the mo which is close to home so fingers crossed. then I can get straight back to working on it
Jack88
Re: Black 5
« Reply #13 on: 21:56, Mon 24 October 2011 »
bought a new bumper to replace the split one
Jack88
Re: Black 5
« Reply #14 on: 23:51, Sun 06 November 2011 »
I came across this for cheap and local so im changing direction a bit
Its got a knocking in the bottom end and the guy I bought it off stipped the engine down, so im gona put my standard lump in it and all the best parts from both cars. Its still going back to standard and I can't wait to get stuck in  :D
