Author Topic: 5th gear  (Read 777 times)
Jermaine1162
5th gear
« on: 20:19, Sun 12 June 2011 »
My fifth gear has gone drove all the way to Santa pod yesterday with only 4gears from Leeds. The problem is I go to put it I'n 5th and there is nowt there. Is it an easy fix Or should I get a new box?????
Re: 5th gear
« Reply #1 on: 21:05, Sun 12 June 2011 »
Is the gear selector in the wrong position? Can you find 5th gear without the engine running?
Re: 5th gear
« Reply #2 on: 23:08, Sun 12 June 2011 »
Could be the 5th gear nut coming loose on the shaft, common fault on these boxs
Jermaine1162
Re: 5th gear
« Reply #3 on: 11:56, Mon 13 June 2011 »
I'll try fix the box 2moz when it warm. Were Is db motorsport I could do with a AFR.
